noteven
Jan 10, 2021Explorer III
Skinny D wrote:noteven wrote:
To release them drive off and then give them a couple gentle hits with something heavy - chunk of firewood - to break them free. If you overdid the hot water freeze in you might have to use hot water to thaw them free again.
My 2x6s froze to the ground last time... only seemed to contact ground/ice on 1 of 6 sides, but I COULD NOT break free a few of them. The ice was stronger than the doug fir and I just hammered off pieces of wood, and ended up just leaving some wood frozen to the ground.
Ya wood is porous and will really freeze down. Wood does not conduct heat from hot water very well for that thawing method either. I had plastic lego levelling blocks in the mind.
The mechanical ice pick method (screws) is better with wood.
I fought with levelling on snow and ice once. I park on the tires now.
