Huntindog wrote:
This is a common question, and there are many threads on this. The common theme seems to be that the Barker owners are very attached to their jacks, almost all of them rave about the fantastic customer service.
....SNIP ....
I cannot attest to Atwoods customer service as in 14 years of use, I haven't needed any. I also haven't read about it here either. At any rate, look the features of both styles over closely and decide which one makes sense for you. Spend the money. Then enjoy it. I hope this helps.
Well the two here are 20 and almost 30 years experience and it's not so much about being attached to our jacks, it's just when something does happen it's refreshing to get satisfactory C.S. especially on things probably well past their normally expected life span.
ALSO ...
Here
CLICKY is just one discussion of ATWOOD C.S. with mixed reviews so now you can now say you have read at least one comment on ATWOOD C.S.
I guess in Atwood's defense like almost all C.S. good service is more common than bad and if you run across one where the bad service is non existant that is what stands out and my read is that Barker is one of those companies.  I personally also like the U.S. based support and talking to someone that can communicate well in English ... something that with many companies is becoming harder to find.
Larry
