Naio's avatar
Naio
Explorer II
May 07, 2016
Choosing between these 3 vans, opinions aporeciated!
When it rains it pours. After a lot of false starts I suddenly have 3 vans to choose between.
All are the same make, model, engine, and trans. (A good one -- I will avoid arguments by not saying which :). )
Van #1: 1 hour from me, 2003, 105k miles, $8800.
Van #2: 24 hours away, 2001,190k but mechanic I hred to inspect says it has been very well maintained, $7900.
Van #3: 12 hours away, 2005, 125k, $6350.
Plusses and minuses:
Vans #1 and 2 have the same camper top and it is one I love. Van #3 has a different top but I included the cost of customizing it to be almost as good.
Vans #1 and 2 have been inspected by mechanics hired by me but new to me, and passed with flying colors.
Van #3 is in a remote area, no mechanic available to inspect, but seller is certified mechanic and bought it for his own use, says it is good. This is also the one mentioned in another thread that has some beaurocratic hassles. (It might sound like I don't like this van, but it is ok with me and cheap! I was all set to buy it till the other two cropped up today.)
Van #3 has super springs. If they are good and the other two vans need spring work to carry the load I will put on them, add $600 to each of them. This is something I don't think I can determine until after purchase.
#3 has power steering cooler and trans cooler. It also has a super duper AC but that is not a priority to me.
So, what do you think?
  • I'd be inclined to go with 1. Lower mileage, sounds like you like it, and #3 could be more of a hassle in the end.
    BTW.... Ipads really don't weight so much that you need Super Springs to carry one around ... :)
  • I'd be inclined to go with #1. It's more money, but it's only 1 hour away (so no expense to obtain), it has the top you want (no expense to customize), and is in good shape. For the increase of $900, you decrease travel by 23 hours and gain 85K miles and 2 years on the engine.
    #3 is cheap, but you aren't real comfortable with the registration. That's fine if it's the only option, but you have other options without that issue. The price is a lot less considering it's newer and you're depending on the seller's mechanic background to guarantee it's condition.
    #2 is OK, but you're losing a lot of potential miles on the engine. With the 24 hours away bit, you'll be adding a lot of miles to it before you even really get to enjoy it. With #1, you can put miles on it camping - not trying to get it home.
