rgredaExplorerJul 28, 2016city water connectionI would like to increase water pressure in my TT. It's permanently hooked up to city water. Is it a good idea to remove check valve for good? I believe it's not working correctly. Thanks. Rich
Old-BiscuitExplorer IIIJul 28, 2016Fill tank and use pump........pump should supply at least 45# and 2.5 gpm flowIf pump pressure/flow is better than city water then check valve is problem
Related ContentQuick connect exterior shower hose doesn't connect.CITY WATER CONNECTION DRIP?Water pump?No water pressure when connected to city water.Quick Connect For City Water
