rgredaExplorerJul 28, 2016city water connectionI would like to increase water pressure in my TT. It's permanently hooked up to city water. Is it a good idea to remove check valve for good? I believe it's not working correctly. Thanks. Rich
wgriswoldExplorerJul 29, 2016You could remove the check valve and just seal the opening with a cap when using on-board water.
Related ContentQuick connect exterior shower hose doesn't connect.CITY WATER CONNECTION DRIP?Water pump?No water pressure when connected to city water.Quick Connect For City Water
