rgredaExplorerJul 28, 2016city water connectionI would like to increase water pressure in my TT. It's permanently hooked up to city water. Is it a good idea to remove check valve for good? I believe it's not working correctly. Thanks. Rich
rbpruExplorer IIJul 30, 2016I had my pump pressure drop off because of a clogged screen filter.Try the water source faucet as ready suggested then each of the TT faucets including the drain pipes for flow.
Related ContentQuick connect exterior shower hose doesn't connect.CITY WATER CONNECTION DRIP?Water pump?No water pressure when connected to city water.Quick Connect For City Water
