Halmfamily
Jun 17, 2016Explorer
corvettekent wrote:
Yes, you water pump has a one way value that is leaking. Some times you can get lucky buy turning off the city water and turning on the pump so it will flush out the valve, then switch back to city water. If that does not work you can take the valve apart and clean it.
Had to do this last week while camping, our fw tank filled while hooked up to city water. Cleaned out the strainer then turned on the pump and all was well after that.
