- JIMNLINExplorer III
CincyGus wrote:
Most videos I've seen applying Eternabond show using acetone. I have seen a few use windex also.
Eternabond makes a cleaner also if your wanting what they recommend. The acetone will be significantly cheaper and has been used for years without reports of any problems.
This as we have no idea what material is on your roof. Same with those that say they use XYZ on their roof material.
Contact your units roof material mfg or the trailer mfg and ask for their recommendations on what to use or not to use.
Most roof materials are compatible with Eternabond cleaners.
And follow their instructions.
And finish the job like the pros with a sealant around the Eternabond edges. - ReneeGExplorer
We used Eternabond's recommended cleaner in the link in this post. It worked well. Our thought was that using the manufacturer's recommended cleaner would be best for adhesion. So far, so good, 5 years later. - winnimanExplorer IIThe eternabond I bought said to use mineral spirits to clean the area. I have used rubbing alcohol with good success. It was I had in stock.
- gboppExplorerI've used Acetone and Lacquer Thinner. They both work well.
Use a roller to apply the Eternabond. I like the steel roller, some people like the wooden roller. - eHoeflerExplorer IIThe instructions that came with mine stated to use either Lacquer thinner or Gasoline.
- hotjag1Explorer III use Brake Kleen. It removes the dirt, dries quickly and leaves no residue.
- IAMICHABODExplorer IIIUse something "Hot" something that evaporates fast I like to use Acetone it is what I have always used with out any problems and have had no failures when I did the very same seams.
44,066 PostsLatest Activity: Apr 15, 2026
