Wishin
Nov 01, 2020Explorer
If you can take a drive before dumping, that does help.
As for residue, I always fill my fresh water tank up with soft water from my house whenever possible. When I can't, I put Calgon water softener powder down the toilet. I also add some high efficiency clothes washing machine soap (apparently it has less suds than non-high efficiency?) down the toilet after dumping each time and add several gallons of water. Then when I'm driving home or to the next campground, the soft water and soap is sloshing around cleaning it out. My trailer has now seen 7 seasons of use and when I drained it out for the end of the season, I only saw black plastic below the toilet. No residue. I also try to flush it out a little better the last time of the season. This time I dumped 2 5 gallon containers of clean water down the toilet after doing my normal drain. Sometimes I have my wife in there flushing the toilet and I shut the black valve for a minute, the let it flush out, shut it again to build up, then open it up again. Do that a few times until it runs clean.
