- patperry2766Explorer IIThanks. I ended up using woolite/water to clean them, so I'll try it with the Protect All when I open it up again.
- ViaSteve2015Explorer II
sbstryker wrote:
Here you go! Everything you need to know: http://www.thepopupprincess.com/pop-up-camper-maintenance/cleaning-protecting-your-vinyl-camper-windows/
I'm a Protect All user....why didn't I think of that! I think I'll definitely try it the next time I clean the patio enclosure windows. - sbstrykerExplorerHere you go! Everything you need to know: http://www.thepopupprincess.com/pop-up-camper-maintenance/cleaning-protecting-your-vinyl-camper-windows/
- tim5055ExplorerI was always told to use Plexus on the vinyl windows. Plexus plastic cleaner
- ViaSteve2015Explorer IIWe have vinyl windows in our patio enclosure (SB home) and Murphy's oil soap was recommended. I used it this spring and it worked well. Make sure you use a soft brush or vacuum any loose dirt or grit off the window first.
Back in our popup days, I cleaned the vinyl windows with a mild solution of a liquid cleaner and water and never had any problems. Our last camper was used for 10 years and the vinyl windows were still in great shape when we traded it in. - patperry2766Explorer IIWOW, talk about a lack of product knowledge. I called Forest River and he didn't know so he referred me to the canvas manufacturer. The people that make the products don't even know what to use either....GEEZ
44,071 PostsLatest Activity: Sep 18, 2026
