VictoriaChanExplorerMay 04, 2018Clogged drain, any solution?Shower drain clogged. Other drains work fine. Some times the water in the show tub just go through the next day, sometimes not. Tried toilet plunger, some water will go when I use it; but the rest w...Show More
MFLNomad IIMay 04, 2018Can you access the p-trap underneath, to remove and clean out? Mine is easily accessed from the pass through.Jerry
Related ContentClogged DrainNorcold fridge - clogged drain tube?Shower drain clog.House battery drainShower Drain Clogged
