VictoriaChan
May 04, 2018Explorer
time2roll wrote:
I would first verify the tank is empty then use some liquid drain opener from Home Depot. I use the commercial grade black bottle. Let it work a couple hours or overnight. Repeat weekly until back to normal.
Otherwise something got past the filter besides hair and soap that will need to be removed by opening the pipe fittings.
Tank is empty. I tried a small bottle drain opener two times, one leave their about 1h, the other time about 0.5h, didn't see any improvement. Probably try yours again.
I am kind worry about using drain opener on the rv piping; just trying to find solutions before I open the shower pan, which is a big project to me.
Thank you
44,071 PostsLatest Activity: Aug 23, 2026
