exintrunk
May 05, 2018Explorer
Dick_B wrote:
I would never use any kind of drain cleaner either at home or on the RV. Go to the hardware store and buy one of those plastic drain claws that has the teeth on it facing backwards. shove it down the drain and move it around and pull out the `stuff'.
Do the same at home.
that works well. you can get them at the dollar store. i have to do all the house drains at least once a year too. you may consider pouring some baking soda in the drain and then follow it with white vinegar. Plunge it a couple times and the resulting chemical reaction should push thru most blockages.
