VictoriaChanExplorerMay 04, 2018Clogged drain, any solution?Shower drain clogged. Other drains work fine. Some times the water in the show tub just go through the next day, sometimes not. Tried toilet plunger, some water will go when I use it; but the rest w...Show More
LynnmorExplorer IIMay 06, 2018You might want to try the wet or dry shop vac. Alternate between vacuum and blowing till it clears.
Related ContentClogged DrainNorcold fridge - clogged drain tube?Shower drain clog.House battery drainShower Drain Clogged
