carringb
Sep 25, 2017Explorer
Mine has the 15k BTU A/C and it cools fine, with nearly double the square footage. I will say that having slide topper makes a big reduction in heat coming through the slideouts, most of which radiates from the ceiling, since the slideout ceilings are much thiner than the main ceiling.
Mine also has the 35k BTU furnace. It heats fine, but in single digits or less it does run a lot, and will deplete the batteries overnight. But again... double the square footage, with 4 slides means lots of area for heat loss.
As for the mattress... Maybe just try trimming a memory gel topper to fit?
44,068 PostsLatest Activity: Jun 21, 2026
