Bob_in_NH
Jul 07, 2013Explorer
CO Detector red/green Fault indicated
Will a weak battery on a popup give you this indication. Book says its a fault indication with the microprocessor and to replace unit. I had no problem before until now when I noticed the interior lights to be dim as well. I thought perhaps a weak battery could be the cause of the alert/fault. I disconnected the fuse for now until I can figure out the problem. Meanwhile I am recharging the battery. Any thoughts or confirmations from anyone on the battery causing the fault??
