bmupton wrote:
As the season approaches, I want to share a story with everyone. Don't worry, it has a happy ending. :-)
Last summer our combination LP Gas/CO detector malfunctioned and would alarm for no reason (No gas turned on, no fuel burning appliances running). The trailer was from 1996, so I just assumed that the detector was faulty and installed a new one.
Then, the next weekend, we had an especially bad wind from one direction that caused the exhaust from the hot water tank to be blown inside the trailer. Normally this wouldn't happen as they should be sealed, but in our case it looked like the tank had been removed and not properly replaced (it only had four screws instead of eight, and the seal looked like it was removed and not replaced). Anyhow, the new detector did it's job and got us out of the trailer.
For the night I just shut off the propane and decided I would deal with it in the daylight. We opened up the windows and ran a couple fans for an hour to clear out any remaining CO. The next morning I sealed the area around the tank and tightened everything up. I fired up the hot water tank and let it run as we normally would, and the alarm did not go off again.
This is a reminder to everyone: check your smoke/CO/LP Gas detectors and make sure they aren't expired and that they have fresh batteries (if battery powered). Don't let faulty equipment end your camping season in tragedy.
Great advice, not only for the Summer camping season but for ALL seasons including at Home.
I keep a battery powered one in my camper and at home I have two (one is line powered only and the other is Line and battery backup. Both are digital readouts (digitals are sweet since they often SHOW a reading way before there is enough to fire off the alarm).
Can't be too careful at my home since I use a wood furnace for most of my Winter heating and have a natural gas furnace for backup and a natural gas water heater...
To think that there IS folks out there camping in the Winter using unvented propane heating devices that claim burning propane and inhaling the exhaust is a safe thing to do :E
Doesn't take much CO to not wake up in the morning...
