lincolnmatthews's avatar
Apr 28, 2017
CO2/Propane alarms gone off twice since we bought camper
Purchased out now 3 yr old Lance 1181 in Jan of this year. Once while plugged into an extension cord along it went off, I figured it was an low voltage issue as the power had been off for a day or so.
Then this last weekend while out plugged into power at a park the alarm went off in the middle of the day for no apparent reason, (no propane smell, been in & out several times etc. So I pulled the fuse & we slept with more than one window cracked open that night.
Of course its mounted down by the floor by the step to go overhead & the fridge is right there, but shouldn't be an issue unless ??
I believe its made by Safe T, do these things go bad? I wouldn't think in a 3 yr old camper. My RV dealer said that if someone used some spray cleaner at some point that this could cause them to **** out. Just hate to spend a $100 at this point for a new one just to see if this solves the problem.
Anybody ever had a similar problem with there's? Might add that the batteries are stored in an outside compartment not in the steps like my last Lance, anyway thanks for any ideas!
  • There is nothing new about this situation. Verify that the propane side of the alarm is going off. That detector is prone to failure. It is not unusual to need to replace the detector every few years.
  • Difficult to say... What I do know from experience: the low voltage alarm (on our unit) was different from the actual leak-detected alarm. Nothing like being woken up at 4 am by that thing...
    These sensors are quite sensitive. Can you have your propane system leak tested (pressure tested) by a professional?
  • Mine goes off every time the old dog sleeping on the floor in front of it farts
    make sure the power/ground wires have tight connections, something may have vibrated loose
