cougarfan
Mar 29, 2015Explorer
I have a 2014 Coachmen FE 246RKS and am very happy with it. I second the comment about the Azdel. I too have some tongue weight issues but just load more things in the bedroom and then put them away when I'm parked. I have a 50th anniversary edition so it has all LED lighting inside along with some other extras.
In my 2014, the fresh water tank is in the rear so I carry just enough water for a few stops on the way to my destination. I usually always camp with hookups so don't need a full tank of water. It also doesn't have a built-in black tank flush but I just use the Flush King and that works fine.
I also looked at the Surveyor but felt the Coachmen with the Azdel was a better option for me. I felt the Cougar's fit and finish wasn't as good as the Freedom Express. Just my opinion of course...
You could also look at the Coachmen Catalina 253RKS. It has better counter space in the kitchen and a bigger tv in a better location. It also has two entry doors. One in the back and one into the bathroom which gives you more space and access to the bathroom when the slide is in. It has aluminum skin instead of fiberglass if that makes a difference to you.
Good luck!
Laura
Good luck!
Laura
