SoundGuy wrote:
Annoyingly, Coachmen still mounts the tank monitor / water heater control panel where it's blocked by the slide when in the travel position.
jjjandrbaker wrote:
Like I said earlier, SoundGuy is a good spokesman for us. Now, I remembered one thing I really don't like. Like SoundMan, I have memorized the buttons for the panel, but shame on Coachmen for not just putting it a few inches to the left in the first place!
While Coachmen IMO got the general design of the 192RBS right there's certainly more than "one thing" about it that can only make one wonder if those who design these trailers actually ever use them. :M Yes, kudos to Coachmen for extending the bed to a full 80" length and providing a vent over the main cabin (both of which are lacking in my 2014) but surely if one gave this any thought at all both these details shouldn't have been missed in the first place. Mounting the tank monitor / control panel where it can't be seen is just one of the
continuing flaws - several others come to mind as well.
The 192RBS is one model that cries out for cabinet doors on the end of the bed platform, so one doesn't have to lift the heavy bed platform & mattress in order to gain access. I solved that myself by identifying the cabinet door above the galley as the correct size, ordering 2 along with all the hardware, and installing them myself on the end of the bed platform. Hard to imagine it would cost all that much for Coachmen to just make this part of the design. :R
The tall pantry to the left of the fridge, next to the entry door, still comes with 2 doors, the lowest section is simply paneled over even though there's nothing behind that panel but open space occupied by a couple of tail light wires. Again, I identified the correct door size from another Freedom Express of the same model year, cut out the panel, and installed the door. We've used that space for storing shoes, last season I carried odds 'm ends of hoses, cables, etc. Current 192RBS models still don't have a door. :R
A pet peeve of mine - the orientation of the slide and awning switches makes no sense at all. After all, when I want to pull the slide in surely I'd want to press the 2-way switch in at the end nearest to me ... instead it pushes in at the end facing toward the outside of the slide wall. Really? :S
The 192RBS's stock fridge is 6 cu ft. After seeing our camper a few years ago friends of ours decided to finally upgrade from their beloved Jayco popup and replaced it with a Starcraft Launch 21FBS which is virtually a clone of our 192RBS. Their trailer came stock with an 8 cu ft fridge ... so if Starcraft can fit this larger fridge into this design why can't Coachmen? :R
Outside the trailer the large entry door handle makes no sense at all. It's there simply because it's a generic item that's used across the entire lineup, in fact on probably all Coachmen models. The problem with the 192RBS is that handle, when folded to the rear to clear the door, sits across the rear awning support arm. Close the awning without thinking about this and that entry door handle will be crushed, just as my wife did on our second trip out when a sudden storm came up and she retracted the awning. I got lucky - only the handle was damaged, the awning hardware was fine so I ordered a new handle but cut it down in size before installing it so this design flaw would no longer be an issue.
Coachmen wisely chose to not mount the spare tire in the conventional manner by hanging it off the bumper where the weight would only unload the tongue. Instead it hangs under the A-frame - good for maintaining proper tongue weight but IMO a lousy solution considering that over time that spare wheel will be exposed to all manner of road debris and rust accordingly. I removed the crank assembly hardware and moved the spare to the front pass through cargo compartment ... tongue weight is still maintained but the wheel isn't exposed to the elements.
I
really like how the external grill pulls out from the side of the trailer even though it was an "option" in my model year but disagree completely that it's a grill and not a stove. A grill will only introduce greasy cooking smells into the camper so I instead park a Weber Q on the campsite picnic table for grilling well away from the camper and replaced the stock grill with a Coleman 2-burner stove which remains free of any cooking smells. I use it every time we camp but only wish Coachmen had instead plumbed in their own permanently connected stove.
And finally there's that sagging fresh water tank which AFAIK hasn't been corrected at all on current models. Fill it with water and it will sag noticeably ...
On current models you just can't see it because the underbelly is now enclosed, unlike my 2014 which has an open underbelly. Lucky me, I saw this flaw right away and was able to correct it
before the tank fell off the trailer. How could Coachmen possibly continue ignore such an obvious flaw? :h
Bottom line - over 5 seasons of use we've really grown to enjoy our Coachmen Freedom Express 192RBS immensely and would recommend it to anyone looking for an easy to tow, easy to park couple's model of this size. However, it's not perfect, the shame being these issues are details Coachmen could easily address to bring this model just that much closer to being "perfect". ;)
