SoundGuy
Feb 18, 2017Explorer
concord 05 wrote:
If this is the set up, how do you hook the bedroom tv to satellite ?
I suspect you probably don't ... feeds inside the trailer are usually routed from the cable / antenna wall plate with the one on the front feeding the main television and a second output on the back side of the wall plate going to the television in the bedroom ... no provision for satellite feed routing, so if that's what you want you'd probably have to add it yourself.
