TIMCONDRA1's avatar
TIMCONDRA1
Coax connector 2011 Keystond Outback
We have a 2011 Keystone Outback and are planning to add Dish tv. There is a coax connector on the outside. Can we use it for the satellite? I have been told that on some campers it will not work because of the way it is wired through the antenna booster. Any help will be appreciated.
  • Thank you very much. I guess I will run the coax up through the floor
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    chris3403 wrote:
    Welcome to the forum. I own that unit. You should have 2 separate connectors on the outside. One is wired through the antenna and the other isn't.
    our 2011 outback has only one connector, it's a cable connector. and no it won't work for sat.
    some 2011 outbacks built later in the year added a sat input.
  • If you don't have the second line then you can run a new dedicated line or try this mod....
    sat rewire
  • Welcome to the forum. I own that unit. You should have 2 separate connectors on the outside. One is wired through the antenna and the other isn't.
