billtex
Apr 23, 2014Explorer II
The COG "over the axle" is a somewhat relative term. If you look at the "camper loading" section of your truck manual it shows a range centered around the axle.
COG in front of the axle would be best.
COG on the axle would be fine.
COG slightly behind the axle is still acceptable...
The camper is made to fit a long bed truck...you are not the first...you should be fine.
In any case...you need to verify the axle load and tire/wheel capacity.
Bill
Bill
44,066 PostsLatest Activity: Oct 04, 2013
