tdiller wrote:
if everything else is cold and this power supply gets warm this can cause condensation.
let your tv come warm up with the camper then turn it on.
The last part is good advice BUT you should not try to speed the warming process by opening the trailer up and letting in warm, damp outside air.
If you want to see a condensation demonstration and you live in the north country, just throw your garage door WIDE OPEN on the first day of Indian summer or of spring where the temperature is in the 60's or more. You will almost instantly have a thick accumulation of water ON EVERYTHING IN THE GARAGE where it looks like it has been raining inside. Warm air on relatively cold objects. (Of course this won't work if your garage is heated to 60 or above.)
You have the first part a bit backwards. Condensation occurs when warm air hits a cold object.....or when warm air is chilled suddenly.
Objects typically do NOT collect condensation when they are heating up from an internal heat source.
