fallsrider's avatar
fallsrider
Cold Weather Camping - plumbing
My wife and I are planning a trip to the mountains of NC, and the extended forecast is showing lows of 19 to 23, with highs in the mid-40s. This particular CG does not have water and sewer at the RV sites, only electric. They have a fill-up spot for filling your FW tank, and a dump station for when you leave. Our FW tank is inside under the bed, so I'm not worried about the plumbing, though there is always the low point drains which hang down underneath.
I'm more concerned with the BW and GW dump valves. Should I be OK with them exposed, or do I need to wrap them with some type of insulation? I've never camped this cold before, with the lows being only about 25 previously. Thanks.
  • I'd get a couple of 5 gal water containers and not use the water system. Done that many times. But that's just me, do you feel lucky?
