Huntindog
Oct 15, 2016Explorer
If you run the heat (you should) then the top of the tanks will be against a pretty warm surface, from the heat migrating out of the TT. This makes pretty cold temperture camping possible without freezing problems. Night time temps in the teens should be OK.
You can even run the furnace while under tow. I have done so when temps were in single digits.
44,066 PostsLatest Activity: Apr 16, 2026
