rod82
Sep 06, 2025Explorer
Coleman 17B
I recently bought a 17b and within 5 months my ac started leaking on inside of trailer..I decided to not keep it level since ...I know have a slight fall to the ac side..still try to leak in.anyone e...
Hey Rod82, I’ve had a similar issue before. The slight fall could be affecting the drainage, but make sure to check the seals and drain line for blockages. Some folks use leveling blocks under the AC to stabilize it. Hope that helps!
