Terryallan
Dec 06, 2013Explorer II
Maybe you just rounded off the end. Drill out the hole to allow the crank to full insert. That could work.
On another note. Never ever sleep in a pup that is not fully up, locked, and has the door fully installed. Alone with other things. The door is a safety devise. It helps keep the roof from falling on you, and smothering you in your sleep, Should the cable, crank, or wiffle tree break. If those things fail. The roof will fall like a express train. The door with hold it up, on one side. Allowing you to escape. You were fortunate indeed.
