Beer_Belly
Dec 08, 2013Explorer
Terryallan wrote:
Maybe you just rounded off the end. Drill out the hole to allow the crank to full insert. That could work.
On another note. Never ever sleep in a pup that is not fully up, locked, and has the door fully installed. Alone with other things. The door is a safety devise. It helps keep the roof from falling on you, and smothering you in your sleep, Should the cable, crank, or wiffle tree break. If those things fail. The roof will fall like a express train. The door with hold it up, on one side. Allowing you to escape. You were fortunate indeed.
Nobody steps into our Pop Up until that door is in place just for that reason.....not even our dog
