work2much's avatar
work2much
Combining battery sizes in parallel.
Hi everyone. Old member that has been on a long hiatus. Our day has come and we are now retired so I am fortifying the camper with extra power in the form of solar panels and batteries.
I removed the Onan 2500 genset to install 2 6 volt batteries instead and added 400w solar panels on the roof. Batteries added are 2 Trojan T-105 RE batteries. I am considering running them along with 2 12 volt flooded deep cycle batteries in the OEM battery compartment. I purchased a charge controller along with the solar panels.
The advice seems pretty divided on mixing batteries like this to form a unified battery bank charged by solar, engine alternator and 110 plug in. Note the 2 6 volt batteries are a good 8 feet away from the 12v batteries and solar charge controller.
Not wishing to start a debate. Researching this I see many opinions regarding mixing different sized batteries in parallel.
Anyone else have experience with this?
  • ScottG wrote:
    This is done every day in the commercial world. I would separate them into two banks and charge them together but use and store them separately. For best efficiency, I would only connect them all together when charging.
    I am certainly not a 12v guru but it seems to me that any of us charging from the trucks alternator are doing this regularly . The truck and house batteries are almost never the same size or type battery .
  • towpro wrote:
    why not just put another 2 Trojan T-105 RE's in the OEM battery location?
    Not big enough.
    This is a common argument that does make sense to me.
  • Thanks everyone for the responses. I have read a few times if the batteries are the same type i.e.: wet flooded that putting them in parallel is ok even with different amp hour ratings. I have also heard many responses like here that it isn't a good idea.
    I am starting to think about keeping both battery sets but only hooking the solar up to the trojans and using it as our primary power source. The 2 12 volt batteries would charge when we drive and serve as a back up that would be available when/if the trojans get down to 50%
    I can install a switch that allows battery A, battery B or both so they wouldn't connected to each other but both available for power. This would also give me the ability to play around using both and go back to one easily.
    I think this will work fine for us. We don't use much power the way we camp. No air, microwave, forced air furnace, big tv's etc.
  • dms1 wrote:
    I you could set up a marine battery switch so you could charge the Trojans and then when they are full, use the switch to charge the other batteries.
    Interesting idea.
  • Unlike paralleled batteries equals one being overcharged and the other being undercharged, with both resulting in eventual damage and reduced capacity.
  • towpro wrote:
    work2much wrote:
    Not big enough.
    Not sure how big your battery case is.
    Mike put 2 in his Wolf Creek, which have enough space for two 24/27 series 12v batteries. but he had to lay them on side.
    http://truckcamperadventure.com/2012/05/lifeline-agm-battery-upgrade/
    The trojans are not sealed batteries and can't be laid on their side. From what I understand mixing battery types is a definite no-no.
    Looks like a perfect set up for your camper though!
    Yep. When I ran my RV setup they were probably run in parallel (for charging and use) about 60-70% of the time. When you try to actually get into the technical specifics of why the "everybody knows" guidance is what it is, the information is somewhat fuzzy and the "damage" or "inefficiencies" you'll see tends to come from conjecture rather than actual testing or experience. Rather than depending on "dumb luck", decide what you want to do, do as much actual research as you can on the specifics, and then make your decision. Your results may occasionally not work out the way you want, but my experience says that you'll have more way winners than losers.
  • "I am certainly not a 12v guru but it seems to me that any of us charging from the trucks alternator are doing this regularly . The truck and house batteries are almost never the same size or type battery ."
    This never got answered, very relevant to most of our TC's, does this not matter because they are only all in parallel during charging, what about the trucks that have 12 volts at all times at the trailer connection.
    This mixes, 6 volt Deep cycles in series, AGMS, Deep cycle flooded and Starter type batteries all in one big pile....
    Will this damage the TC battery types over time, or just affect the efficiency
    of the charging from the truck alternator...
