Hi to All from a pair of newbies. Herself and I are doing our homework before spending any $$. As there are only the two of, plus Chester the cat, we have already decided that we want a smaller TT...
900 excess is not alot. Consider the water weight alone. Have you figured in your own weights? That also goes into the towing weight of your truck. Good luck in finding the camper you want. We ended up with recliners that weighed less then the sofa. But then again you may need the sofa. there are so many choices. We are six foot and the RV queen is good enough for us but definately like the walk around or edge around as it is tight.
