JoeChiOhki
Oct 28, 2015Explorer II
Boatycall wrote:
I'm only throwing this out there, but have you considered possibly an extra battery or two and an inverter? I'm a HUGE fan of inverters over generators. That and a couple solar panels and you'd be set.
Inverters do not drive large roof top A/C units, and I already have three heavy deep cycles and an inverter.
With my original camper, I was able to get by on a 1500watt generator, but I had a little A/C unit. Now, I have a large A/C unit, one of the old Duo-Therm Quick cools, and am stuck looking for a 3200watt generator.
The Onan popped up for $500, so I figured I'd do a little investigating.
NRALIFR wrote:
The Generac's that used to be installed in TC's by Lance and others were 3600 watts. It looks like Generac has gotten out of the built-in RV generator business though. Honda also left that market a few years back. It looks like the only manufacturer of the smaller built-in RV gen-sets that you could use in a TC now is Cummins Onan.
2500 watt is probably about as small as I would go, but it's going to be dependent on what you expect to run on it. If you want to be able to turn the A/C and microwave on at the same time the reefer is running on AC power and the battery charger is pumping out max amps, 2.5K might not be big enough.
Aye, given I have the Duo-Therm, and it came off a fifth wheel, I'm looking at likely needing at least 3200watts, the unit in question is a 4000 watt unit, so its in the ball park of wattage needed.
