dadmomh
Mar 28, 2015Explorer
Have never set foot in either so just personal opinion here....I would much prefer to have a window in the door...not only for light but for the security factor. I want to be able to see if someone is at the door. On the Grey Wolf, I'm not a big fan of the stone-look/pseudo fireplace entertainment center. Just prefer the wood of the Wildwood. Can't remember which had it, but I like the appearance of the glass kitchen cabinet door inserts but not sure if it would be a problem with the bumping and swaying enroute. And unless you keep the cabinet neat and tidy, could be an eyesore. Otherwise they appear about equal.
Agree that a salesman will always stress that the model on his lot is a higher quality than the same basic model he doesn't have. Suggest you make a return trip with a checklist of some things like quality of the cabinets, hardware, comfort of the bed, quality of the fabrics and flooring and anything else that comes to mind. The sticker put on at the factory on the front street side will tell you where the unit was manufactured....could be a give-away. With the ROO HTT we had vs the Flagstaff Shamrock, they go down the same assembly line, made the same way, only the decals, fabrics and some minor details are different. If they were made at the same factory, you can seriously consider that they're the same with different decals, etc.
Which dealer are you most comfortable with? Confidence in what you're being told? Remember to do your own homework and not assume that what you're hearing is true. We are on our second Forest River trailer and have been pleased with both. No problems other than a loose wire in the stereo and it was fixed before we headed home. Strongly suggest that if there is an open campground nearby, you make that the stop for the first night. It will give you time to go over everything and if you find any glitches, you're right there to get it fixed before heading out.
Good luck...either is a nice looking trailer.
