bid_time
Jan 18, 2017Navigator
I am not married to any brand, any manufacturer can make a good RV or a inexpensive RV all in the same building. All of the different brand names of any manufacturer are not all of the same quality. If for instance you buy a Forest River product, they have zillions of brand names and different model names within those brand names. Just because your neighbor has a Rockwood "whatever" doesn't mean if you buy a Rockwood "something else" they are of the same quality. One could be built for full-timing and last forever while the other is built for an entry level buyer, built for occasional use, and built to be inexpensive. Totally different target audience, totally different build quality, totally different target price range, same brand, same manufacturer.
This is a major purchase and should not be taken lightly. You should take your time and do your research first before you plunk your money down. This forum is just one little piece of it. There is a lot of good information here and some that is really a disservice to you.
The only way to determine quality is by getting your blue jeans dirty. Inspect the RV stem to stern, climb over, under, around and inside every nook and cranny; open drawers, look behind panels, lift up seat cushions; crawl underneath it and look at the frame and everything underneath; compare what you see to many, many different brands (within similar price ranges) and determine how the unit is really built, what it’s made out of, and how its put together.
When I inspected the different brands I looked at craftsmanship, type of construction, materials, thickness of materials, methods of jointing, welding, bracing, etc. From that I was able to eliminate several brands within similar price ranges right off the top. After that I looked at floorplans and the ability to use the TT while traveling (like stopping for lunch or a quick potty break) without opening it up. And this narrowed the decision down more. You have to do your homework. It took me over 9 months to do the thorough research necessary before I put my money down.
You need to know what you are buying, what your intended use is, how long you plan to keep it, and then you can decide what price range you are shopping for. Bang for the buck first (quality), then comes the floor plans and other amenities.
