gordinho80's avatar
gordinho80
Comparing Ram 1500s
Hi all. I'm looking at replacing my current truck, 2001 F150 Super Crew with a newer Ram 1500. I'm looking at the 1500s because I don't think I will truly need a 2500.
We have a 2000 Coachmen 2790TB which has a GVWR of about 7400 lbs. 1500s with the 5.7 Hemi are capable of towing this size trailer just fine, I think. Plus we will only be going out a couple of times a year at first, maybe a 1000 miles round trip max. Rest of the time, the truck will be a daily driver. I don't commute for work, so I would really only be using it to drive to a from our families' houses 45 minutes away every week.
The 2 on my short list right now,
2011 1500 Crew Cab Outdoors package 5.7 V8 with 3.94 gears and larger AT tires with the 5 speed auto (545RFE).
2012 1500 Crew Cab SLT Big Horn package 5.7 V8 with 3.55 gears and the 6 speed auto (65RFE).
Both are similar in price, 2011 priced at $1k more than the 2012. The 2011 also has what they list as the 205mm HD front axle as opposed to the 2012 215mm axle. 2011 also has an Anti-Spin rear differential.
I'm leaning more toward the 2011, to be honest, mostly due to the axle ratio. Price difference is really insignificant considering both are priced at below KBB, but the 2012 is listed at $2400 below KBB while the 2011 is only $800 below KBB with the higher asking price. Not sure how much wiggle room there is there in the price... so lets say both stay at these prices. What would you all pick?
