myredracer
Apr 19, 2016Explorer II
The following is based on my experience. (Apologies for being long.) I love our DC hitch and wouldn't change it for anything else except for maybe a Hensley or Propride. Getting it all set up properly did not happen overnight tho. You may want to ask to have this thread moved to the towing section - there's a few there with extensive experience with the DC hitches.
First, do NOT ever let a dealer touch one of these WDHs, let alone any other WDH. These hitches are somewhat finicky to install and set up and it's better if you study up on how to do it yourself. They are an excellent WDH with their integral self-centering pro-active sway control. Secondly, you need to weigh the TT asap to get an actual tongue wt. You can't just slap one of these on and go and expect it to work properly... You will find that you need to go through a process of adjusting the bar angle, number of chain links under tension and adjusting the cam position (to center on the bar's "notch") over a period of time before it works optimally.
The cam arm bracket mounting bolts *can* back out sometimes. One factor is the tongue weight. I've read of this happening at tongue weights of around 1200 lbs. Ours loosened a bit (were properly torqued) and our tongue weight is around 950 lbs. Specs for the Salem TT (29BH I assume?) has a GVWR of 9165 lbs (UVW + CCC). Typical TW is around 12-13 percent of trailer's weight so using the GVWR as a max. wt., the TW *might* be 1191 lbs. Occasionally TWs can be up to around 15%. Ours is about 14.5% the last time I went to a scale.
The rivnuts are better than just using the forming bolts, but they have a shoulder on them which is proud of the A-frame and the bracket will not be tightly flush against the A-frame tubing. For TWs on the heavier side, they *may* or *may not* hold up. You could probably install a say min. 1/16" plate with holes large enough to keep the rivnut shoulders away from the brackets.
It appears that you might be in the range where bolts have a higher possibility of not staying put. The A-frame tubing is only 1/8" thick which results in less than 2 threads being engage by the Reese forming bolts. I would use the Reese DC hitch without the cam arms installed until you go to a scale and weight the TT fully loaded up for camping. Provided the bars are rated 1200 lbs and not the next ones down which are 800 lbs. 800 lb bars will not work properly with a TW near 1191 lbs.
You should ensure that you have the correct spring bar rating. 1200 lb bars *might* be okay but you need to know what you have now. What is the TV? Hopefully the receiver is rated 12,000/1200 lbs (max 1200 lbs TW). If the TW is over 1200 lbs, you'll need an upgraded receiver and higher rated Reese dual cam WDH. IIRC, 1200 lb bars are good for 1,000 - 1,700 lbs but if over 1200 lbs actual tongue weight, will need the 1,700/17,000 hitch head/shank.
Another thing to know is that Reese's trunnion spring bars vary in length. The 800 lb bars are about 1/2" shorter than the 1200 lbs ones but Reese does not say this anywhere AFAIK. Not sure about their 1700 lb bars. Reese specifies a distance of 19 3/8" from the coupler to the cam arm brackets. The problem I found is with 800 lb bars, there was not enough thread left on the cam arms to position the cam where it needed to be. I had to upgrade to 1200 lbs shortly after getting the 800 lb bars which solved this. If I were you, before drilling any holes, temporarily position the brackets with some C-clamps to make sure you can move the cam arm forward or rearward enough. If had stayed with the 800 lb bars, I would have been faced with drilling new holes to re-position the brackets.
If your TW is indeed much over 1000 lbs, you may want to avoid just using the Reese forming bolts or the Rivnuts. Not wanting to ever have our bolts back out again, I drilled holes into the A-fame, welded nuts to a plate and inserted the plate into the tubing from the end of the tubing. Link to a thread with details on how I installed the plate and Reese brackets. The photos below should how I did it.
Keep an eye on the snap-up brackets if the TW is on the high side as they can bend, break or otherwise become damaged and even damage the A-frame tubing. You may want to consider using one of the Reese forming bolts (maybe along with a rivnut) - there is a hole provided for that. IIRC, the snap-up brackets on the 1700 lb Reese package are stronger.
How old are the dual cam brackets? A few years ago they had a run of poorly made brackets which do not fit up against A-frame tubing very well. I got replacements directly from Reese. Even with their better made ones, the radius of the brackets does not mate up against the A-frame tubing the greatest and for heavier TWs, it's worth installing a spacer to help overcome this.
Links to some previous posts I made on the brackets:
dual cam brackets Photo of the older/newer bracket profiles:
44,070 PostsLatest Activity: Aug 05, 2026
