Skinny_D
Feb 01, 2021Explorer
Gdetrailer wrote:
As I mentioned, there is built in "drains" in the windows, they are hidden from view, moisture collects on the window surface then rolls down to the bottom.. At the bottom of the window there is a couple of well hidden drains that send the moisture to the outside of the frame.
Take a close look at the outside of the window frame, you should see two plastic "covers" at the bottom of the frames.. Those are the drain points.
You should not have to "mop" the moisture at the bottom of the window frame unless the drains are clogged..
Drains are there to help redirect any moisture that gets past the window slide gaskets in heavy rains..
Won't hurt to mop it but not really needed..
That's some info that I needed! I was wondering about that... whether there was some weep holes in the window. Of course, that sacrifices insulation but helps get rid of the moisture. See pic below. I went right out and inspected and that's what I found. I presume that's the weep hole.
In that case, I'll just get one of those little bathroom squeegees and squeegee the moisture straight down toward the trough at the bottom. Then it can go out the holes and the cold window is primed to condense additional moisture. I'll run the dehumidifier when convenient as well.
As a side note, I'm not sure that heating up the air actually dries the air (in pretty sure it doesn't), but it does help the dehumidifier work more efficiently. Hotter air has a large capacity for holding moisture in vapor form. So the meter reads a lower %RH just because the capacity of the air to hold moisture went up... not because there is less moisture in the air.
44,052 PostsLatest Activity: Oct 13, 2025
