JoeChiOhki
Jul 28, 2016Explorer II
rockhillmanor wrote:
We all run the fridge on propane. Usage of propane to run fridge while traveling is negligible. The flame should NOT blow out on a properly functioning unit.
You need to focus on what is making the flame blow out, repair it and you should be good to go.
Haven't figured out how to "fix" 60+ mph side gusts that aren't uncommon crossing the desert of eastern Oregon in a north-to-south direction.
I tried everything that would solve that, cleaning the thermocouple, adjusting the shutter, hell I even duct-taped over parts of the vents to try and block the wind that was getting pile driven into the side vent and down through the top vent that kept blowing it out.
For those that don't think theirs is going out, it likely is when a broadside hits, the difference is, your unit is relighting it and just simply hasn't had it happen often enough in a row to trip the fault and shut down the fridge ;).
44,066 PostsLatest Activity: Jul 25, 2018
