Also look at where the width cross beam are on the bed vs the top of the tire. The builder that made the bed for my navistar, put a cross beam at the high point of the tire, so when at or near max gvw, the tire would rub on the cross beam. BLEW tires up left and right. At my last wood bed redo, I removed the cross beams where the tires are, No issues since.
Also some builder will only use say a 8" c channel for on top of the truck frame. Check your spring drop limit, and you can sometimes go with a 7 or 6" channel, that will lower the bed height. Granted only and inch or two. that inch if you load things by hand, can be a measureable amount. Same with cross beams. . I have also seen some beds recently made with plastic wood. About half an inch thick. So another way of lowering the bed height vs using 2x wood material as I have. Lowers the overall weight of the bed vs steel, heavier than wood. If you load pallets, the plastic could be better than wood or metal, as things may slide in and out easier. Have not heard anything from people I know that have them as to being super slick from things moving while breaking or taking off.
If I was doing for a pickup tomorrow, I'd look into the folding side boards that at least locally for me, the rental Home Depot trucks have. Iss ue with this, if you use a fork lift, when the sides are down, you could hit with the lift, and bend it. You do have more room than a stake side side board, as these are only an inch thick vs 2-4" depending upon the thickness and what your side board is made of.
Another option to look at, depending upon what your haul, is going with an 8.5' bed. This could give you a full 8' between the side boards. or if you need a bit wider bed for hauling an implement, you have it.
Marty
