SoundGuy
Jul 18, 2018Explorer
josephc wrote:
My family is in the market for a new travel trailer, and one problem we're running into in deciding what we want is figuring out what we can safely and legally tow. Specifically, we're unsure if we need to consider a trailer's GVWR when deciding if it fits within our GCWR, or if we should consider what it actually weighs when we end up loading it up and taking it to the scales. A lot of advice seems to suggest we always consider the trailer's GVWR, but this has led to some confusion on our part.
It's not a trailer's GVWR that matters but it's GVW - what it weighs fully loaded & ready to camp. Sometimes GVW ends up being close to GVWR, in which case one could simply use GVWR as a basis for calculations. However, in many other cases CCC is so great that one would have to carry a ridiculous amount of junk for GVW to come anywhere near GVWR so it would make no sense at all to use GVWR as a guide. The most common reason for is that axles, suspension components, tires, etc, aren't selected for just one model but rather a series of models in the same lineup - it's just more cost effective for the manufacturer to do it this way, buying a trainload of the same sizes that will be eventually be used on a variety of trailers they build. The result is that a trailer weighing say 3500 lbs dry could easily be wearing the same set of axles as another model weighing say 5000 lbs dry, or 6000 lbs, or whatever. Case in point is my own Coachmen - short 19' couple's model has the same axles, suspension components, tires, etc, as much larger, heavier models in the same lineup. It has well over a ton of CCC, far more than other models in the same lineup and far more than similar models from other manufacturers - for example the Starcraft Launch 21FBS which is the exact same layout, actually a foot longer, but has a CCC of only 1200 lbs. Reason - axles, suspension components, tires, etc, selected for use by that particular manufacturer, for whatever reasons. Regardless, you're always better off with as much CCC as you can get whether you're going to actually use it or not. In my case, even in the worse case scenario where I'm carrying content in the tanks, my trailer still weighs at least 1000 lbs less than it's GVWR - LOTS of buffer, which in turn means less stress on all those components. :B All that said, what you should be basing your calculations on what you can safely tow is by far what your tow vehicle's payload capacity is as you'll run out of that long before you'll get anywhere near it's GCWR.
44,056 PostsLatest Activity: May 04, 2014
