donn0128
Jul 18, 2018Explorer II
All these replises seem to miss the point. Can you safely tow a trailer with a higher GVWR than your TV is rated for? Certainally you can as long as you stay under your TVs rating. However, what happens when you want to take a longer trip, or have guests? You could very easily bump up against your trailers GVWR, thereby exceeding your tow vehicles ratings. Now its not a totally bad thing. Your TV will not instantly explode or anything. But the driving experience sure could cause some anxiety. Most any vehicle could pull way more load down the road, but the bottom line comes down to safety and comfort. Are you safe on the road? Are you comfortable loaded to the max on the highway with other drivers? Its not always about you, but about the other driver. Could you safely handle the max load in an emergency situation? That my friend is the questions you need to ask yourself.
44,056 PostsLatest Activity: May 04, 2014
