2012Coleman
Jan 28, 2015Explorer II
OP wrote:Sorry, but this statement is misguided. There are many things that subtract from your payload - and the big taker is tounge weight. Tounge weight is calculated at 12 or 13 percent of the trailers Gross weight - not dry weight. So if your loaded trailer weighs 7000 lbs, thats 840 pounds subtracted right there using 13%.
Our kids weigh less than 100lbs combined, so in people weight we arent transporting much.
You then subtract another hundred lbs for hitch equipment - hopefully your considering a weight distributing hitch and your TV has the proper tires.
Next subtract weight of all occupants - pets included plus the weight of all the stuff you put into tyour tow vechile.
You can see why others have stated that towing capacity is the least important number. I suspect that you will be well over your TV's capabilities with a trailer of the size needed for a family of 5. Post a picture of the sticker on the door jamb...
44,072 PostsLatest Activity: Aug 23, 2026
