carringb wrote:
They can leak worse! I did a demo on a mobile home with a 1-piece AL roof. Because it was flat, water crept in at every penetration, and the sealing compounds did not seem to deal as well is Dicor on EPDM membrane. Properly installed maintained, EPDM should last a very long time without leaks.
I have a 1990 and a 1991 35 ft and 36 ft trailers with single sheet alunimum roofs, neather has ever had a roof leak, or required much sealing maintainence work at all…
Carringb , I am going to guess your problem was with the sealers you used not the roof…
