Nvr2loud wrote:
sch911 wrote:
Why bot avoid those friction units altogether (which are very ineffective), and get in to a real sway controlling hitch like the Equalizer or Hensley?
BTW: Definitely do not lube the friction bar, and tighten it as tight as you possibly can...
I don't know the OP's reason, but for me it is price. I can not justify 500 dollars or more just for a better hitch.
Safety should be the most important thoughts on your mind...always. it may,seem like an initial expense that is awful expensive. But, just suppose your camper ever went into an uncontrolled sway and you wrecked perhaps causing death. Considering this scenario, which can happen to anyone, well... as for me, I think the $500 is pretty cheap. My current hitch system cost a bit more than that, but I also have no sway issues. The cost is more than worth the alternative.
