Freep
Jun 23, 2018Explorer
joerg68 wrote:
Wouldn't the wobble stoppers have a fixed length once set?
As far as I understand the mechanics, you could still push the fastguns in some way (make them
shorter) even when they are locked/engaged. And as they are spring loaded, you can probably still pull them out a tiny little bit. Also the hooks at both ends are not suited to take any load except pulling.
The only point of the three you make which couldn't easily be dealt with by the positioning of the anchors seems to be the spring loaded point. I didn't consider that the wobble stoppers might not be spring loaded too. I knew there had to be a reason someone hasn't done this yet.
44,056 PostsLatest Activity: Jan 12, 2020
