usmcbecker
Mar 25, 2016Explorer
Converter Humming, probable short
Good day everyone,
I usually don't like coming on a forum and taking up all your time, but I feel like I have hit an impasse with my trailer that I cannot overcome. I have a 2014 Autumn Ridge by starcraft with an electrical issue. I am unsure what is causing the problem. The biggest issue that is driving me crazy is the converter box is humming. Not overly loud, but if there is nothing on, you can hear it all the way in the bedroom. I've pulled all the fuses to see if I could pinpoint where it is with no prevail, it still hummed. I have sanded down the ground points to the frame to ensure a good ground.
The battery won't hold a charge either, even when shore power is or isn't connected. I've charged my battery up and let it sit a day in my garage and it held a charge fine. My power tongue lift keeps blowing fuses as well. The fuse is currently blown as I felt keeping that out of the mix would probably be best until I have found the issue.
Any advice would be much appreciated, since I felt I have done everything in my power to try to locate this possible short without luck.
