time2roll
Jun 17, 2020Nomad
Yes if you have an open slot you can pop in a breaker and have a separate converter circuit. Assuming you power the entire panel you can just switch the converter breaker off as needed.
If you have a 30 amp RV NEC only allows 5 branch circuits. So technically you are not to code. I have 7 so that my rarely used converter or tank heaters can remain off most of the time. Never an issue.
Yes lithium has advantages. Most answers are for a fairly tight budget.
1800 watts is a lot of solar.
