pianotuna
Jun 17, 2020Nomad III
tmckenna wrote:
Ive taken a fair amount into consideration.
Most of the batteries that Im looking at have a maximum charge rate of 50 amps. So thats 600 watts at 12V. In terms of solar that basically means that you can use up to 6 panels to charge 1 battery.
3 batteries means I can have up to 1800 watts of solar charging at one time. Which would also be just about enough to maintain the same battery level even while running the Air conditioning.
For now its really just a pipe dream for over prepared off-grid life/travelling, but in theory its pretty solid.
Also, I'm aware that wanting to run AC off a battery setup is mostly unnecessary, but as I said itd be nice to have the option.
If you are serious about running the roof air from an inverter, please consider moving to a 24 or 48 (preferred) volt battery bank.
Magnum does NOT recommend running the roof air from their 3000 watt hybrid inverter/charger.
The similar sized Victron will run the roof air.
I'd go with SiO2 batteries (summer of 2021 for me), instead of Li. They are about 1/2 the price and can be used and charged at -40. One feature they share with Li is not needing to be fully recharged as there is no sulphation.
My roof air, when first run, draws about 1300 watts. After running a few hours that goes up to as much as 1900 watts. So wattage needed for a 13500 BTU A.C. is a "moveable feast".
