pianotuna
Jun 27, 2020Nomad III
tmckenna wrote:
Either way I think I would add the breaker so I have the freedom to control the fridge or the converter individually. I guess its mostly just a piece of mind thing to be honest.
I would just use a switch. Breakers are not intended to be used as switches. My converter draws about 700 watts, when running "flat out".
I used to use the converter before I had a hybrid load support inverter/charger to do "double conversion". I.E. in low power situations, I would plug in just the converter, and then run the rest of the RV from a 2500 watt MSW Cobra inverter.
