brulaz wrote:
Veering off a bit here...
Does the PD go into Battery Charge leading eventually to Storage Mode whenever the trailer is plugged into 110VAC? Ideally it would, as the battery is not needed when plugged into 110VAC.
The PD manual says:
STORAGE MODE: When the converter senses that there has been no significant battery usage for 30 hours the output voltage is
reduced to 13.2 volts DC for minimal water usage.
But my WFCO does NOT. Only if I remove all the DC fuses will it drop the battery charge voltage below 13.7V.
I'm not sure about the OP's PD converter, but I added PD's "charge wizard" to ours...
PD Charge Wizard Info.
This upgrade allows us to have 3-mode charging capability... Boost (14.4v), Normal (13.6v), Storage (13.2v).
Happy Camping!
John.
